putting together motor - which way do rods face and which way to hang pistons
24ounce
well i searched and didnt find anything - this is my first engine build and its a 3.1 with l24rods with floating pins on standered ka24 pistons
i know the pin in the piston is offset to stop thea slap garbage and the rod has to be a certian way for the oiler
so now if im looking at the front of the block which way should the oiler be facing right or left?
and should the short side of the piston be on the left or right?
also according stonehinge i need to use a sealers on the rear main cap - what should this be just any regular permatex or dose it need to be somethign special??
also should i be using any certian kind or assembly lube or will anythign i pick up at a parts store be just fine?
