Wiring Confirmation - Relays, Fuse Blocks, etc.
ktm
I am in the final stages of acquiring the necessary parts to complete my turbo build. I've been thinking about the electrical connections and have come up with the following setup.
I will use use the following fuse block (top one):
Marine Block
for my power distribution. I see no reason to run a terminal block and a fuse block separately as this fuse block solves both issues.
I will then run power on the fused side of the connection to each of the following relays: two for the headlights, up to two for the fan (if a two speed fan), EMS, fuel pump, and whatever else I can think of.
The cost is slightly more than if I went with a terminal block and a generic, non-weatherproof fuse block, however, it is not that much more. Since nearly all of my relays are for 'external' components, it makes sense to have a fuse block in the engine bay.
Thoughts?
