Guest JAMIE T Posted March 24, 2002 Share Posted March 24, 2002 I have cut the front of my car completely off. I am building a tube front subframe like Ron Jones' car has(thanks Ron for the Photos, you sent them to me about 6 months ago) All suspension mounting points remaain in the stock location. The roll cage tubing extends to about were the old radiator support would have been. The upper strut mount attaches to the rollcage. I am using coilover conversion and full ZF Racing Suspensions(of course) adjustable arms on all four corners. My car is not a Drag only car, it is going to have a R230 rear eventually, but a welded R200 for the time being. I will have pics when I am a little further along. Quote Link to comment Share on other sites More sharing options...
QWKDTSN Posted March 24, 2002 Share Posted March 24, 2002 Oh dear!! This I've gotta see! I think this is one step where you can definitely say that it's all the way or nothing at all. I don't think I'd have the cojones to cut off the front clip of my car even after extensive measurements and research... you did all that right?? Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted March 24, 2002 Share Posted March 24, 2002 I was supposed to take measurements? Yeah, I took measurements. But, I have another car to go by if things go craZy. I made the frame BEFORE ever cutting the old clip off. Now, I just need to cut the old frame(sheet metal channel under the car), and grind all that smooth, and grind the firewall smooth(at the cut points). I will likely fill in all of the un-used holes in the firewall as well. Quote Link to comment Share on other sites More sharing options...
Guest super280z Posted March 30, 2002 Share Posted March 30, 2002 dang Jamie, it really has Got to be EXTREME for ya hunh? good luck bro, Quote Link to comment Share on other sites More sharing options...
