Will I need to align my car if I take camber out...
I am using the EMI camber plates. It doesn't seem to me that taking out camber would affect the alignment of the front tires. Is that correct?
I"m currently at 2.2 degrees negative in the rear which is a bit much for street tires..
Fronts are about the same. I was planning on going for about 1 degree negative both front and rear.
When I decide to go racing again, I can re-adjust, but the car is street-driven now (at least until it gets too hot to drive a non-AC Z car!).
TIA
Usually that much of a camber change will change the toe enough to make the car twitchy and noticably increase tire wear.
If I were going to change the camber, I'd change the toe also.
John
