Quagmire Posted April 7, 2007 Share Posted April 7, 2007 Hi all , I'm new to this forum so a big hello to you all. I'm changing my timing belt on my Turbo Z31 and does anyone know the corerect amount of slack / tension there should be when installed? I think you measure the slack between the two cam gears, is this correct also? Cheers Scott Quote Link to comment Share on other sites More sharing options...
1FASTKINGCAB Posted April 7, 2007 Share Posted April 7, 2007 If you run a straight edge across the top of both gears you should have 1mm of "sag" -OR- about a half-inch deflection with 20 lbs. of force straight down in the center of the cam gears. Quote Link to comment Share on other sites More sharing options...
Quagmire Posted April 7, 2007 Author Share Posted April 7, 2007 Cheers for your help. Quote Link to comment Share on other sites More sharing options...
