Guest Anonymous Posted April 21, 2002 Share Posted April 21, 2002 Finally have found the time to get Mike Kelly's control arms on my Z. I have been out driving it for the past two days and am pleasently supprised with the ride quality(if our cars actually have that) I have a few questions about final suspension settings. Car is primarily an agressevely driven street car that sees a couple of schools a year. I'm figuring a little negative camber at all 4 corners, (1 degree or so) no rear toe,and 5 degrees of castor. Any suggestions on front toe settings? And also, this would probably best be answered by Mike K or some of you guys running his parts, can I get five degrees of castor with the TC rods mounted solid, that is with out a rubber bushing between the TC and the unibody? Any suggestions and/or feed back is appreciated. Thanks Mark Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 22, 2002 Share Posted April 22, 2002 Mike Kelly, any input. John C? Quote Link to comment Share on other sites More sharing options...
