Yoak Posted April 17, 2007 Share Posted April 17, 2007 Hey Gang, I had my Megasquirt II (PCB 3.0) installed into my 240z, we are now having some trouble with fuel map settings. I reloaded the firmware on the acuall unit, 2.3 with the same ini. I can communicate with the ECU Via Megatune, and was able to write to it in a test. Any advice here. When car is powered on the lights will all light up and then go off. Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted April 18, 2007 Share Posted April 18, 2007 So what is the problem - do you need a fuel map, or is there another problem? Quote Link to comment Share on other sites More sharing options...
Yoak Posted April 18, 2007 Author Share Posted April 18, 2007 at this point it appears we only need a map Quote Link to comment Share on other sites More sharing options...
mobythevan Posted April 18, 2007 Share Posted April 18, 2007 There are some fuel maps listed in the map sharing sticky for different engine configurations. Quote Link to comment Share on other sites More sharing options...
z-ya Posted April 19, 2007 Share Posted April 19, 2007 at this point it appears we only need a map Can you give us more details (engine, ignition, fuel injector flow rate, etc.)? Quote Link to comment Share on other sites More sharing options...
