1970 project
So far....
3.0 engine
Rebello ITS N42 head
Apple Hydraulics SU's
ZTherapy SM needles
Port matched intakes
Rebello coated headers
Nissan Comp crank pulley
Polished flat tops
Carter fuel pump
Holley fuel pressure regulator
Griffin radiator
Crane optical ignition ?
MSD ignition ? Opinion...I have both...
'83 close ration 5 spd
Nissan Comp 4.11 LSD r180 diff
Compomotive 15x7 front 15x8 rear wheels (Hankook ventus)
(road)
Einkei 15x7 front 15x7.5 rear wheels (kuhmo V700)
(track)
Tokico short springs
KYB struts
poly bushing kit
Supra seats
Simpson harness
Finally took the Z for a drive. Kitt Peak, a telescope complex about an hour west of Tucson. Car reacted well to the altitude changes and pretty much did everything I asked of it. I did come to one conclusion......COIL OVERS NOW!! Need to address the camber issues, more in front much less in the rear. Lots and lots of push. Still, too much fun.
BTW... What spring rate are you guys running on your coil overs? I was planning on 250 and 275.
  • 1 year later...
Installed Weber 44's, Canon long intake, Rx7 oil cooler, Ground Control coil overs, CF fender flares, Hoosier cantilevers, custom drive shaft, custom axles, Wilwood front brakes, Hawk pads and headlight covers. I think I'M about ready for paint, finally.
