454 supercharged MS/EDIS almost there
mobythevan
Everything is in place. I finished machining my SC pulley spacer today so the 36-1 trigger wheel fits on the crank. I'll get some pictures of it and some video of it running. Just a few small things to finish up and I will fire it again on the test stand. I test fired it back around Chirstmas with a carb and HEI dizzy. Since then I have been collecting the final parts, fuel injectors, rails, FPR, TPS, pigtails, etc to finish the throttle body injection and EDIS system. I have four 1600cc injectors on it, a 60gallon per hour pump(which is just barely going to make it), 950cfm throttle body. I also have water injection kit for it, but I will install that after the MS/EDIS is working.
