Project240z.com 73 240Z + 83 L28ET + MegaSquirt = SM2 autocross car
Well, I've been blogging about my project for quite some time now, and actually posting videos somewhat frequently. I figured it was time to start a thread here to track future progress as well.
For now you can check out all my older videos here.
http://www.project240z.com/Videos/tabid/54/Default.aspx
And all the old blog posts here.
http://www.project240z.com/Blog/tabid/53/Default.aspx
There are some pics up here, but I've been doing video more frequently than pictures for this project so far.
http://www.project240z.com/Photos/tabid/55/Default.aspx
Thoughts welcome!
  • Replies 75
Dad and I got a bit done on the car this weekend. I've created two videos, one from Saturday, one from Sunday.
Saturday: We ended up running around looking for more plugs for the intake manifold, ended up not having any luck at all with that. We also took some time and found more metal to use on the floorpan. After returning we fabricated a throttle linkage and then i decided it was time to actually see some resemblance of a car, so I partially assembled the front end with the new (new to me) air dam I picked up that afternoon.
[youtube:gUx4mhIfb38]
http://www.project240z.com/DesktopModules/EngagePublish/itemlink.aspx?itemId=21
Photos: 486059431_ae3b590d3a_m.jpg
Sunday: Welding day. I spent most of the day welding, grinding, cussing, welding, grinding. And now I have a passenger floor pan without any holes in it! Alright, there are a few holes that are supposed to be there, and then there are a few holes that can be filled, but they are tiny compared to what I started with.
[YouTube:OdNaHEqvKno]
http://www.project240z.com/DesktopModules/EngagePublish/itemlink.aspx?itemId=22
Photos: (in reverse order)
  • 3 weeks later...
I got some work done on the car, I think I figured out one of the biggest holdups I've had.
The JPipe on my motor (the pipe from the Turbo to the Throttlebody) was mangled pretty bad, so much it wouldn't get a good seal on the throttlebody. Last night I cut about 4 inches out of it and bashed it with a rubber mallet for a while. I think I managed to get it where it will get a seat on the throttle body and still connect to the turbo. At least, hopefully a good enough seal the motor will run, after it runs the pipe will be tossed as it'll get replaced with an intercooler.
After playing with the pipe for a while I finally got around to removing the wastegate cover, tonight I'll test fit the downpipe onto the turbo. Here are some photos from last night.
511680556_c649864acc_m.jpg511708451_78d3f96434_m.jpg 511682036_db0f403f6c_m.jpg 511709595_b07e5ace6a_m.jpg 511683454_f833b66842_m.jpg 511684156_4fd127c770_m.jpg 511711777_41c134103c_m.jpg 511712479_b7e7c4c596_m.jpg 511686158_4201a02c4f_m.jpg
  • 3 weeks later...
Yet another blog post/update
http://www.project240z.com/Blog/tabid/53/EntryID/56/Default.aspx
Last night I returned the Vertical sander that I had purchased from Sears that was broken when I removed it from the box. I got a replacement sander and brought it home to install. I setup the webcam on the wall, right above the work bench, and got to work assembling the sander.
5-10 minutes later I was ready to start sanding on the aluminum I had cut with a jig saw the day before to make a blockoff plate for my AAC valve on the intake manifold. I tell you what, a vertical sander is a fun thing to have! Here's the result of what I was making, though I'm still going to drill a hole in it and tap that hole for the temperature sensor I'll be mounting in the intake manifold.
I also got to use my new drill press to drill the holes in the plate, it all worked really darn well.
After getting the plate made I decided it was time to remove the intake manifold from the car so I could tap and fill some of the holes on the manifold that I don't need to use. I brough the webcam with me and mounted it directly above the motor on the chery picker. I started removing bolts, then decided to read the haynes, it told me I need to remove the Turbo and a few other things to get the manifold removed, I guess I should of planned things a bit better and done most of this work BEFORE I put the engine back in the car, it sure would be a lot easier to get to.
Once I realized how much I had to remove to get the manifold off I decided I didn't want to do all that last night, it was nearly 10pm by then. So I moved to the other side of the motor, bringing the camera with me to the other side. Andy and I decided last week to remove the attachments for the oil cooler for now, I'm going to attempt to get the car running without the cooler for now, and reinstall it down the road as I don't have all the hardware for it.
So I started removing it last night, got it removed, and then saw that without the attachment there isn't a way to mount the oil filter to the block. So tonight I'll be attempting to remove the oil filter attachment from the parts motor (78 l28e) to see if I can use it on the 83 L28ET.
After all this I decided it was time to head inside and play with the cool video I had shot last night, only to realize that I had click on the record audio button, instead of record video. So yet again, there isn't any video to be had :(
Tonight though I promise I'll do my best to get it right and have a video to post of the evening's work.
So I spent some time tonight working on trying to remove the intake manifold from the car. Long story short, I didn't get very far and I'm going to pull the motor back out of the car on Saturday. Getting parts removed off the motor is a huge pain in the rear with it in the car, so I'm just going to disconnect the driveshaft, motor mount and transmission mount and pull the thing back out for now.
I'll probably take this time to look at replacing the fuel rail and injectors while I have it out of the car. I need to pull it out so I can retap some of the holes I need to fill, as well as clean it out, I'm sure it has all sorts of crap in there that I'd rather not blow into the motor the first time it starts up.
Here is a link to the video from this evening. Nothing too interesting, but a cool camera angle. Removing the motor on Saturday should make for some good video...
With the help of a buddy of mine I was able to get the intake manifold removed from the car, as well as the exhaust manifold and the turbo.
I had hoped to have video up today but for some reason my laptop apparently decided to have some troubles with the video file from today. I do have the engine removal on tape, in high def. I got a new video camera today, Natalie and I needed one (she's got a lesson with a very big name in training on Monday that she wants me to record), the camera is amazing. I hooked it up to my plasma TV and holy cow, my garage looks better on TV than in person! I'll work tomorrow to get the HD video off that camera.
I have a few hours of video with my normal webcam setup, hopefully this chkdsk I'm running now will repair one of the videos. Otherwise it looks like I'll only have the motor removal from the webcam, not the 2 hours of work after that removing all the intake/exhaust manifold parts.
What's next? Cleanup time. I'm going to be ordering a fuel rail, injectors, pressure system/guage, and look into options for cleaning up the intake manifold. I may end up trying to have some machine work done on the manifold, and have the intake/exhaust manifolds coated before I go to put them back on.
More on that later this week. Hopefully video later tonight, if not sometime tomorrow.
Here's a link to the Video
I finally got the video working from my new camera. I installed Windows Vista again last night on my home Machine (after 4 months of running on XP again) and with Vista the camera works great!
You can see/download the video with the URL below. But please right click and save the file, it is large. 180mb, but I think the quality is well worth the wait for the download.
http://www.christoc.com/p240z-6-16.2.wmv
The 240Z once again stands on its own! Eric and I put the brakes back together on the car, put the wheels on and roll her out into the driveway. Spun her around, and rolled her back in. Then we procede to begin on the fuel cell installation (read cut ♥♥♥♥ out). Tonight I'll be working with Dave and Eric to cut more, and start fabricating the mounts for the Fuel Cell which I hope to have mounted by the end of the week!
Here's the video from Saturday's work
Tonight was a semi productive night on the 240Z, which is always a good thing when some productivity happens during the week, it's hard enough being productive on the weekends. More on tonight in a bit. Summit Racing kindly sent me all of the fuel part oddities I had ordered last week. I had a 12x12 box sitting at the office when I returned from lunch today. I was dissapointed to find such a small box, after spending so much money! But I guess I did order "small" parts.
After work I headed home and met up with Dave from http://www.soloperformance.com/ who came over tolend a hand. First we hypothesized on how to mount the 15 Gallon fuel cell I have for the car. I think we've come up with a good plan, and I hope to start fabricating that later this week. After going over that plan we started cutting and fabricating new seat mounts for the Project240z. We got quite a bit done on the Passenger side of the car. I started on that side just incase I were to screw something up, I can always drive without a passenger seat if needed, but I'll always need a driver's seat!
Here's a link to the Video I took tonight. Towards the end you'll notice a small camera issue, the tape came loose and the camera basically inverted, which made for some kinda cool video as well. I also took some pictures of what we accomplished on the seat mounts.
636965520_eac5c8cd1f_m.jpg636958506_55c6875b8d_m.jpg 636952016_ee9017c342_m.jpg 636945914_3030bea5cc_m.jpg 636940408_8a7ea563db_m.jpg 636071817_49cf2f0efb_m.jpg
Tomorrow night, or Thursday I plan to finish up the passenger side brackets and get started on the driver's side brackets, as well as to start cutting for the fuel cell. I'll have to pick up some more 4.5" cutting wheels though, I've gone through 3.5 of them in the past two days of working on the car and have plenty more cutting left to do.
I say tomorrow or Thursday, because I'm not sure I'll get any work done tomorrow (Wednesday) because I may head off and play roller hockey with some guys I used to work with at The Sporting News (www.sportingnews.com), they are in the process of relocating the "online" side of TSN to North Carolina and I think Wednesday night is the last night for Ray Slover at the pickup hockey games that have been going on for the past 5-6 years now.
More later this week!
I spent another hour or so tonight working on the passenger seat mounts I hope to get some bolts tomorrow and attempt to mount the seat into the car tomorrow night or Friday.
I'm still waiting on my fuel rail from Lone Wolf Performance. I hope to hear from them tomorrow and have the part by Friday. If not I'll have to find myself another source for a fuel rail.
Goals for this weekend. Mount both seats in the car, though I'll pull them back out until I'm ready to leave them in there for a while, they are too nice to keep in such a dirty car till it gets cleaned up! I'm also shooting for getting the fuel cell all fabricated and mounted into the car, along with fuel lines run to the front of the car.
Well, after figuring out that the seat mounts I had made earlier in the week wouldn't fit I went back out to work on the 240Z this morning with a bitter taste in my mouth.
I started off with a few quick pictures of what I had put together the other day.
673184455_9b64476202_s.jpg673190431_880cfb4a9d_s.jpg673195651_d64c4bbdc1_s.jpg674062246_7c66fdf691_s.jpg
From there I removed the Corbeau brackets and started grinding the welds down on the tabs that I had added to the cross braces. I removed all four tabs with little trouble. Being that I haven't welded much before, this was the first time I'd had to remove a weld, so I wasn't sure what to expect. Here is the end result after removing the tabs.
673205413_498c671f98_s.jpg674071368_ca7e55930a_s.jpg673215677_8c8af90109_s.jpg674083032_9fe4134d3e_s.jpg674088766_c7d403672d_s.jpg
From there I got smart, I decided to do a bit more test fitting of the seat before I did any more welding. I attached the Corbeau bracket back to the seat and put it in the car, using towels to keep the seat clean.
For the new positioning I decided the seat brackets basically needed to come forward in the car 4 to 5 inches from the original tabs I had made. With the two cross braces in place I wasn't comfortable making tabs that long and with little support, so I installed two more cross braces into the car, in front of the two existing braces.
These two new braces were each welded at the body, and then to the original (from earlier this week) brace in the middle, actually reusing the tabs I had recently removed to add some support in the middle. I then welded on new tabs, this time spanning both braces on each half of the seat, adding support to the tab, as well as making the tab 2" wide instead of 1.5" as I had originally made. This should create for better support of the seat brackets. Here are the photos of the newly created tabs and cross braces.
673247061_e1d2c9e8cf_s.jpg673253349_28177b0167_s.jpg673258863_81ab7419cf_s.jpg673265749_78fef8c31a_s.jpg674131972_069ae9895d_s.jpg
674137570_524a72b49d_s.jpg674142596_f3811289be_s.jpg673285983_696e9f3987_s.jpg673291071_0c4bc236b5_s.jpg674157068_0c3eb83175_s.jpg
I position and drilled holes for the Corbeau bracket in the new tabs, visible in the latter photos above.
After getting all of this setup I was anxious to get the seat in the car and see how she fit. To get the seat in the car I had to mount the Corbeau bracket directly to the seat with 4 bolts that will go through the new tabs in place. I wrapped the seat in towels and put on some clean latex gloves so that I wouldn't get the fabric dirty from all my gunk.
In order to actually thread the nuts on the rear bolts I have to tilt the seat backward, for now this is alright, but when I actually go to use the seat this won't work well. What I think I'll do is get a combination of some rubber and metal washers, which I think will allow me to tighten the rear nuts down and still be able to tilt the base of the seat back a bit, once tight, lower the front of the seat into it's tabs and tighten up the bolts there. The front tabs are easy to access, the rear tabs, not so much. Anyways, here are the photos of the seat in the car.
673315591_2eed7f4631_s.jpg673319285_f60ef41a13_s.jpg673323819_1f5cc2d7b4_s.jpg673328497_9f43a1d962_s.jpg674193116_3fdba6ab68_s.jpg
Tomorrow I'll be installing the driver's seat, most likely in the same manner as the passenger side, I'll also be starting on mounting the fuel cell, cutting out sections of the rear floorpan, and then fabricating a frame for the cell to sit in. The ultimate goal for this 15 Gallon cell is to build a frame that will allow me to easily remove the fuel cell and install a smaller cell. Using the larger cell for Time Trial and HPDE events, and having a 5 gallon cell to use for autocross events, saving weight in the rear of the car.
More tomorrow!
Originally posted here
This morning I set out into the garage to tackle a fairly large task, at least in my mind. My goal was to build a frame that will secure my 15 gallon fuel cell to the Project 240Z. In case you don't want to read the rest of this post, I was successful!
I began with a few shots of the car before I started cutting into it (further than I cut last weekend). There are various shots here, above and below.
688010251_c5f52df804_s.jpg 688014903_30f5d0d433_s.jpg 688029701_f164521805_s.jpg 688025165_33f872e8e8_s.jpg 688885702_21916b9649_s.jpg 688906740_35837eb263_s.jpg 688917226_1a8f198255_s.jpg 688911408_f17497bbef_s.jpg
After taking those shots I got to cutting. Dave (from www.soloperformance.com) and I had discussed how to mount the cell into the car on Tuesday when he came over, so I had an idea of what I wanted to do. I quickly marked some lines to cut with a sharpie, then proceeded to tear up two cutting wheels removing metal from the rear of the car. I don't know why that stock metal tears up wheels, but they sure to go away quickly when cutting on the car. Here are photos of what was left after cutting.
688065565_3cb0b3ffd7_s.jpg 688056387_98b20f1e34_s.jpg 688936738_48089af809_s.jpg
The intention for the fuel cell frame was to bolt a bar on the back of the rear differential mount, weld to 1x1" square tubes parallel to the ground running towards the back of the car, then come up at a 90 degree angle from those tubes with more square steel. Those two vertical posts would weld to a bar running inside the back of the car, this bar would also be bolted into the car, not welded, so that if necessary the whole frame can be pulled out with minimal effort.
Here are a few pictures of the end result of the frame, as well as some of my crappy welds! I figured out with all but two welds done, that I had somehow adjusted the wirespeed on the welder in the wrong direction, and that was why I was having a horrible time. I think they''ll hold though, they just aren't very pretty!
688115833_e1930f3e70_s.jpg 688109549_a5cc7e147e_s.jpg 688144105_559adb3e84_s.jpg 688999916_5aada5ac23_s.jpg 688995844_a7931c7423_s.jpg 688125127_d1cfcf1290_s.jpg 688120403_d4321a942e_s.jpg
This frame easily goes in and out of the car, which should come in handy if I ever need to remove the rear end (which I plan to when overhauling the suspension, after the car runs). Here are a few shots of the frame sitting in the car
689025574_1ccdf2341e_s.jpg 688154559_9cab5f76d4_s.jpg 689015196_bbcf458700_s.jpg
And here is the end result, the fuel cell sitting in the frame, sitting in the car.
I think the frame turned out great and I love this photo
The tank sits just low enough, it is barely visible from the back of the car, I actually had to walk 10 feet back and down a couple feet of driveway incline to see either the tank or the frame itself. I've yet to bolt the frame to the car, but that can wait. I'll get some nuts, bolts, and washers tomorrow for the various things I need to mount, fuel cell, seats, etc.
All in all I'm really impressed with myself, I got a lot more done this weekend than most weekends, though I still have the build the driver's side seat mounts (I finished the passenger side yesterday). What's next? Well like I said, tomorrow night I'll be building the driver's side seat mount, as well as visiting Mr. Whittle's house to test fit some fuel injectors into my new fuel rail that should be arriving and the old intake manifold. If the injectors he has fit I'll be ordering injectors on Tuesday.
After that I'll be running fuel lines, and be working on putting the motor back together so I can attempt to put it back in the car next weekend if all goes well. That might be a lofty goal, but this whole project has been lofty for me, so why quit shooting high now!
Originally posted at www.project240z.com
Take 2, stupid internet browsers, I typed this once, I guess that's what I get for not typing it up in Windows Live Writer instead of in the browser.
As anyone who has read the blog consistantly will know, I never get as much done as I "plan" to do in a given time frame, this weekend so far is no exception.
Thursday I got most of the driver's seat mounts welded into place, but I didn't finish them off, I left the tabs for the actualy mounts off.
Friday night I tested some rust remover on the exhaust manifold, no luck on removing any rust with the products I tried.
This morning I got up at 9:30am, lounged around for an hour and a half. I went out to the garage and welded in the tabs for the driver's side seat mount. From there I was all over the place, here's a list of things I worked on today, in no particular order
  • Test fitted new injectors in fuel rail/intake manifold
  • Cleaned the intake manifold
  • Cleaned the exhaust manifold
  • Test fitted IAT sensor in intake manifold
  • Cleaned the transmission and bell housing
  • Scraped undercoating off the car around the transmission tunnel and floorboards
  • Removed all the stock fuel lines (3)
  • Mounted the fuel pump and bracket
  • Test ran some new braided fuel line (need to buy more as I don't think 20ft is enough
  • Prepped the driver's side interior for paint (removed paint/primer, will do passenger side and paint later this week)
I've gotta try to hit the junk yard tomorrow, also will be racing Jansoon's M3, so we'll see how my first BMW experience goes.
Here are photos of the driver's side seat mounts, as well as the prep work for paint.
752096840_be37281eb3_s.jpg 752099866_3f9362f400_s.jpg 751250551_7f15e2f898_s.jpg 752105664_01ab7202dc_s.jpg 752109062_9ff7b177a0_s.jpg 751260177_0bdd7c588c_s.jpg 751263123_04840461b3_s.jpg
Tonight I spent some time working with fiberglass in the car. I was hoping to repair a few of the holes in the floorboards.
I made quite a mess, but learned quite a bit. Here are some before photos.
782283845_4a98080c53_s.jpg 782279103_f6dc23edc9_s.jpg 783148832_a6df33f0c1_s.jpg 782269191_d6fa0b7cc4_s.jpg 782264087_70a0e9c215_s.jpg
782259683_327fb1836a_s.jpg 782254643_7c9e474a2d_s.jpg 783124258_ae0f26041a_s.jpg 783119184_472925df95_s.jpg
The passenger side needed the most work as it was in the worst shape due to rust. I used quite a few pieces of fiberglass matt on the passenger floorboard covering some of the holes. I also covered up a few of the sharper metal pieces of the floorboard.
783197250_28ce5b432c_s.jpg 782316363_c4d5cd8385_s.jpg 782310645_f9e7b3bdf7_s.jpg
On the driver's side I used minimal fiberglass matting and mainly used resin. The driver's side was in far better shape than the passenger side so I used resin to smooth out the surface on the driver's side. It turned out far better than I could have imagined! You can't really see it in the photos, but it's quite a clean look on the driver's side now. I can't wait to see how all this looks once painted. Though before I paint I'll be cleaning up the fiberglass with some sand paper.
783180804_24310b5776_s.jpg 782300717_6712bc4068_s.jpg 783171108_1e2817f6d2_s.jpg 782292067_7163ecacfd_s.jpg
I'll spend some time Thursday and Friday night working on the floor. I hope to try to paint the interior this weekend. The interior may have to wait though as I hope to finish up a few other things this weekend, mainly the fuel lines and getting the motor back into the car.
Originally posted here.
After yesterday's fun Eric and I spent some time in the garage today. I was awoken this morning around 8:00am by the doorbell, the Dish Network guy showed up right on time, more on that topic tomorrow on http://TheMadBlogger.org. After I got the Dish guy going I sent Eric an SMS to let him know I was out in the garage working.
The first thing I need was to lay some fiberglass in the passenger floorboard. I had missed a few spots on that side earlier in the week, and layed some extra resin in the floor to smooth out the pockmarks from the cleaned up rust.
While I let that dry I pulled the extra rear end that I had in the garage so I could start cleaning it up. As soon as I saw the rear end/suspension sitting in the driveway I immediately noticed a difference from the rear suspension that is on the car currently. The current suspension doesn't have a rear sway bar, the spare does. That's fine and dandy, I'd prefer the rear sway bar, the problem though is that the fuel cell frame that I fabricated fits right where the sway bar goes on this spare suspension.
I'm not sure what I'll do with that aspect, but Eric and I spent the rest of the morning taking apart the spare rear suspension. We cleaned a lot of parts, figured out that the shocks (at least on the rear) are KYB's, they do look to be fairly new (or unused as that may be more correct). We got just about everything apart, and came up with plenty of parts to clean and paint (Powdercoat for Rande?) later in the project. Before I can use the rear swaybar I'm going to have to figure out what I'll need to change on the fuel cell bracket to make it work. I might be able to move the mounts for the bar a little higher to allow me to use the cell as currently fabricated.
From there Eric and I started to prep for paint the interior. We cleaned up some of the dust that had gathered, drilled some pilot holes for the seat bolts in the floor (to get to the rear brackets for the seat mounts we had to cut a whole for a socket to fit through). We brushed, vacuumed, wiped and scrubbed the interior to try to get it ready for paint. We lowered the car down off the jackstands and spent the rest of the afternoon painting the interior with a nice satin black "Chassis Saver" paint that I had picked up on Saturday morning.
I had purchased a gravity fed spray gun back in 2003 when I had the 350Z, previously using it once to spray some waste of money wax on the car, the gun hadn't been used since then. I think the paint this time around turned out great, an easy low cost solution that is WAY cleaner than it was prior to all this work. It was a bit laborious, but I think well worth the effort, Eric agrees.
Here are some before pictures
409594222_9c3c5b701f_m.jpg 498988300_ad19a541c5_m.jpg 782279103_f6dc23edc9_m.jpg
And here are some after shots.
824938492_9f563166b1_m.jpg 824668014_2b20a5cdcd_m.jpg824056123_dcc0ec1cf2_m.jpg 824677014_903f6fd289_m.jpg
There are more photos in my Flickr set for Project240z.com
Tomorrow I'll be working on the motor again. I hope to get the intake and exhaust manifolds back on the motor so that we can put it in the car Tuesday or Wednesday night. From there it'll be time to start wiring up the Megasquirt.
Monday night I didn't get crap done on the project! I started to work on the oil filter/block attachment only to realize after driving around for 2 hours that I wasn't going to find any easy way to block off the oil cooler attachments for the 83 L28ET motor. By the time I got home from that it was well after 9 and I needed to spend some time with my wife.
Tuesday I ordered AN fittings to go from the metric 18mm x 1.5 oil cooler fittings to AN -10 fittings so that I can run steel braided lines to the new oil cooler I ordered. All of that should be here tomorrow.
Tuesday after work I began putting things back together on the Intake Manifold. I spent far too long digging around the garage trying to find parts I haven't seen in a few weeks. Yes, I need FAR BETTER organization in the garage. I'll probably have to spend some time Thursday or Friday night cleaning up if I'm going to have anyone over to help out this weekend. After that I headed off to Speed Sports up in Bridgeton (http://www.speedsportstopfuel.com, store hours from 7-10pm M-F) to pick up some AN-4 steel braided line for my turbo oil feed. I got a 1/8" NPT to AN-4 fitting, a 90 degree hose fitting, and the fittings I needed on the turbo side, as well as 5 feet (about 1 ft too much) of AN -4 hose. I figured out when I got home that the port on the block for the oil fitting is NOT 1/8" NPT, it's actually 1/8" BSPT, which is very similiar, but different enough to make my fitting not work.
With this info, I think I've now figured out why the pipe thread plugs I had purchased a few months ago wouldn't work, I probably need BSPT for those as well. I've found a few parts online that I can order to convert from BSPT to NPT, I'll see if anyone locally has those tomorrow, otherwise I'll get those ordered tomorrow.
After leaving Speed Sports I headed down the street to Autozone. At AZ I picked up a lot of hoses, clamps and other random bits of things I needed to reassemble the motor. I also picked up a GM open element Air Temperature sensor to thread into the Intake manifold to be able to tell what the air temp is going into the motor, I had to get the Wells part, I think SU107 was the # but I could be wrong. AZ didn't have a pigtail so I'll try Carquest tomorrow to see if they have the pigtail so I can wire this up to the megasquirt.
After running around this evening I got to thinking about how much this project has cost me lately. Without going into specifics (because my mother will read this) I've spent more this month than I spent to purchase the car. June was the same, and possibly double what I've spent so far this month.
I know I've got a few more things I'll have to purchase, but hopefully I've got all the big items out of the way, at least for this phase of the project.
More coming this week, and I promise to start doing video again!
After work last night I got to work on the car. Eric and Russ came over to lend their assistance as well. Russ got started on the leaking wheel cylinder, Eric started putting the Intake/exhaust/turbo back onto the motor, while I worked on fabricating a bracket to mount the VR sensor onto the side of the motor.
While they were both productive, I actually never got my portion of the project finished last night, though I hope to finish it up tonight. Once the intake/exhaust and turbo was all back together we went ahead and began the task of putting the motor back in the car. I've got some High Definition video of that process here on this Video Page.
With Eric and Russ' help we also managed to get the drive shaft connected up and the transmission into the cross member under the tunnel. Tonight I'm going to pick up more bolts, so we can mount the fuel cell bracket to the floor of the car and then we can hookup all the fuel lines. We'll also be installing the fuel rail and injectors tonight so we can hook up the fuel lined up front.
At that point I hope to start trying to figure out the wiring for the car, that's the big project left for this weekend, get wiring going so we can try to start this bad boy up.
Here are some various photos from last night
859220320_8cec17934b_m.jpg859217242_cc8858e8ea_m.jpg 858361631_e4f89b9d4d_m.jpg 859214472_ec49a9eb30_m.jpg 859211940_d79e827c57_m.jpg 859209068_3ed1601503_m.jpg 858345267_7aff524e8b_m.jpg 859197900_15097a5cf9_m.jpg 859194550_170ce6b801_m.jpg 858342513_1cf86880fc_m.jpg 858339487_e543d157d4_m.jpg 858327679_718ef292b7_m.jpg 859183144_10593bba41_m.jpg 858324807_84dfb7e2e7_m.jpg 858319009_40f14430b2_m.jpg 858315975_2c95e5a4c9_m.jpg
Saturday Update:
Eric and I got a bit done today. Mostly learning with the help of Andy Whittle who stopped by to assist with some Megasquirt questions. I also did some soldering on the Megasquirt wiring, LOTS more soldering to do tomorrow!
The fuel cell is mounted, Eric started on the oil cooler mounting, we ended up figuring out that I did have the correct peices for that, so all that money isn't wasted.
Sunday tasks
Connect Fuel Lines
Run Megasquirt Wires, Fuses, Relays
Install Megasquirt
Install Fuse Panel
Install Battery (charge battery)
Install Seats
Install Radiator
Connect Starter
Connect Alternator
Add Oil to the Motor and Transmission
Add Coolant
I'm sure I'll have to add more to this list.
