Guest Matthew123 Posted May 5, 2007 Share Posted May 5, 2007 Do the msa cams use the stock timing marks on the timing chain and gears? Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted May 5, 2007 Administrators Share Posted May 5, 2007 Well, those are Schneider cams that MSA sells and you “should†be able to trust the timing marks, but in all honesty you should double check the cam timing on the cam card against what you installed using a degree wheel. Just as with everything that you purchase in life, there is always that chance that the cam you received could’ve been ground first thing on Monday morning the day after the company party and the person setting up your particular cam blank in the grinder wasn’t able to index it correctly for lack of mental capacity, etc. Read this thread entirely… http://forums.hybridz.org/showthread.php?t=111523 Hope that helps, Paul Quote Link to comment Share on other sites More sharing options...
