Safe to run oil pressure to the turbo without the turbo spinning?!
I am going to test some things to see if my engine is smoking or if its the turbo.
I was going to un-bolt the 4 bolts holding the turbo onto the manifold and rotate the turbine housing down and run an open manifold. This way I wont have to remove the turbo and block up the oil lines.
