Guest soldier_boy1863 Posted May 14, 2007 Share Posted May 14, 2007 i want to put the weber triple carbs on my 280zx but came across these are they worth the extra money or should i just stick with the carbs. thank you for you help Quote Link to comment Share on other sites More sharing options...
Devil-Z Posted May 14, 2007 Share Posted May 14, 2007 i want to put the weber triple carbs on my 280zx but came across these are they worth the extra money or should i just stick with the carbsthank you for you help You know, it seems to be an epidemic of huge proprtions with America's youth, that they can't type a clear, concise, legible thought on the internet. Punctuation is your friend and makes you better understood. This mess of a run-on sentence is painful to decipher. What is "these" that you are refering to? There is no description of "these," or a picture of "these," so we can't help you. Quote Link to comment Share on other sites More sharing options...
TheNeedForZ Posted May 14, 2007 Share Posted May 14, 2007 at least he's polite, and that's more important in my book Have you looked into these ? http://forums.hybridz.org/showthread.php?t=120562 The maker of those new TB's offers a deal of 1800$ for six IIRC The biggest difference between ITB carbs and ITB EFI is that carbs needs a venturi, it's always a compromise between vacuum signal and flow. A smaller venturi gives you better response, but limits flow at higher rpm. A bigger venturi flows more, but does not benefit lower rpm performance. An EFI system does not need venturi, but you need to know how to tune it with aftermarket systems, perhaps a laptop. Quote Link to comment Share on other sites More sharing options...
