Timing chain, how tight is too tight.
datman
Hi Guys
I'd like a little advice please.
I just rebuilding my F54/p90 using a 2mm head gasket. I fitted the new timing chain and tensioner/sprockets today and its seems very tight. When I turn the crank to allow slack at the tensioner there only about 1mm of the tensioner shaft showing and hardly any play in the chain....is this normal consdiering the head gasket and new chain?
Any advice would be a great help.
Thanks
We set up race motors to have no shaft showing and no chain slack. In fact we use a big pair of Channel Lock pliers to pull the curved guide toward the straight guide when we tighten the bolts holding down the curved guide. Otherwise your cam is jumping back and forth all over the place...
