can you feel the HEAT???
Justin, thanks for the advice, since this is my first aluminum rad, i'm not familiar with them, i was thinking about a soild mount, i'll check the JTR mounts, if not, i'll just fabricate some here in kuwait with rubber support
VinhZXT, well, yesterday i was chekin the space and how to mount it, i'm not really sure that i have enough space to make a shroud, i'm not even sure if i'll be able to mount the fan between the rad and the water pump pully, my engine is not sitting all the way to the back, so space between rad and pully is tight. i'll see how it goes and post photos when its installed.
thanks again for the advice
  • 3 weeks later...
good news :)
i've just finished installing everything in the car, the fan is a pusher now, fired the car for 20 minutes maybe without driving it, the temp didnt go over the middle ( i dont have numbers on my guage) when i used to drive it before, while running, the temp was at 3/4. so i guess it will drop more now when i run.
just wanted to thank everybody for the ideas and help :)
