Oppinions on different bare metal coatings..
Guest 240 4U2NV
Guest 240 4U2NV
Well I'm finally getting ready to start working on my z again after a long break. Its a early 73 240z with rusty floor and frame rails. I am planning on fixing the obvious rust and the floor and frame rails first. Then I am thinking I'm going to have it media blasted by a local shop. My question is what to do once the metal is bare. Should I let them coat it with their normal primer, insist on epoxy primer, or go with a rust preventer. I've read a lot about this but I'm not sure what the best route is. I'm thinking of having it coated in picklex, rust bullet, zero rust, or epoxy primer. Please correct me if any of the following is incorrect
Picklex:
Pros
Clear - at least it looks like it from what I've seen, would be cool/helpful to see base metal
Can be top coated - no need to remove it all before final prime and paint
Prevents future rust
Don't have to worry about time to complete repairs/surface rust
Cons
Not sure where to buy it
I would have to brush it on at home after repairs
Rust Bullet
Pros
supposedly the best
can be top coated no need to remove before final prime paint
prevents future rust
Cons
Not clear - not sure how much of a big deal this is
Zero Rust
Pros
Comes in a spray can so I can spray areas after repairs
Can be top coated
Cons
Not clear
Epoxy primer
Pros
good base for finish work
most likely what the shop is used to using
probably cheaper then the above rust stoppers
Cons
Doesn't prevent future rust
I wouldn't be able to apply at home after repairs (no spray gun)
Any advice or experience you all have had with these products would be great.
