Mycarispurty Posted June 10, 2007 Share Posted June 10, 2007 To you guys that have removed the heating/ac in your Z; did you guys plug the lines coming out of the front of the engine that ran back to the firewall and the one that is on the back of the block that returns the coolant to the block? Or did you just run the big long hose from the front into the rear connection? I'd like to remove that if all possible with some sort of plug I could get at the hardware store, or whatever is reccomended just to clean up the engine bay, however if it can't be done and coolant HAS to flow out of that then I guess I could leave the hose and just recycle it into the back of the block. Quote Link to comment Share on other sites More sharing options...
Guest 280ZForce Posted June 10, 2007 Share Posted June 10, 2007 I used to run the hose from the front of the block to the back of the head, but I just recently bought plugs for them. I haven't started this engine yet, but I've seen some of my friends do this just fine. If you plug it up, you need to get allen head plugs from a hardware store. Quote Link to comment Share on other sites More sharing options...
TimZ Posted June 10, 2007 Share Posted June 10, 2007 Plug them... http://forums.hybridz.org/showthread.php?t=107364 Quote Link to comment Share on other sites More sharing options...
Mycarispurty Posted June 11, 2007 Author Share Posted June 11, 2007 Ahh I got to looking and the water inlet at the front of the block on my car doesn't have the removable fitting for the hose that runs alongside the block. I'd rather have one that does have that so I guess I'm going to have to gank one from a guy with a parts car. Thanks for the help Justin and Tim. Quote Link to comment Share on other sites More sharing options...
