84Nissan300zx Posted June 21, 2007 Share Posted June 21, 2007 does any body know if this can be done? Quote Link to comment Share on other sites More sharing options...
mtcookson Posted June 21, 2007 Share Posted June 21, 2007 Upper, lower, or both? You might be able to modify a VG30E(T) lower to accept a DE(TT) upper, but it would definitely take a lot of work. I definitely wouldn't try messing with a DE(TT) lower due to the differences between the SOHC and DOHC heads. In the end it would probably just be best to modify the stock ones. There are plenty of guys making 400-500+ on modified VG30E(T) plenums. Quote Link to comment Share on other sites More sharing options...
GrayZee Posted June 22, 2007 Share Posted June 22, 2007 Guys have been known to use 90+ Pathfinder uppers. They flow alot nicer and bolt right on, although a few other mods are required. The have a acticle about it on z31.com I believe. Quote Link to comment Share on other sites More sharing options...
mtcookson Posted June 22, 2007 Share Posted June 22, 2007 The main problem with the Pathy manifold is that it is very tall. To fit in a Z31 you have to basically modify the hood. One guy just put some washers between the hinges and the hood in the rear to lift the rear up allowing enough clearance. Other than that you'd have to do some sort of hump, scoop, or cowl "induction". Personally, I'd go for the 2nd gen Maxima manifold. MGP (Molten Gold Performance) can modify them to flow even better than stock and stock are actually pretty close to the Pathfinder plenum. With the Maxima plenum you actually mount it pointing out front, which can make routing piping much easier. http://www.redz31.com/turbofaq/mod.plenum.html http://www.redz31.com/pages/plenums.html Quote Link to comment Share on other sites More sharing options...
