L28et less muffler
JessZ
I've taken off the muffler to my stock l28et set up on my 240z and since then the car seems to idle rougher and actually die at idle. I was under the impression that turbo motors did better w/o back pressure? The car is faster at wide open throttle, which is what I was after, but it's just the idle thing now. I was wondering if I should simply turn the throttle nut to raise th RPM @ idle, or can I lean the fuel to help eliminate the rich smell, and in turn raise idle RPM a bit?
Thanks ya'll,
jesse
That curious to me then, because when I had no muffler (L28et) originally the car did the same thing, then I put the muffler on and it stoped, then just today I took it back off to that RRRRRace car feel back and the low idle thing started again. I know my '83 electronics are crap, but it still seems odd.
Well as it turns out there were two vaccum leaks, one small and one a little larger which happened to pop up roughly the same day I cut the muffler. My Z always throws in a little kink for me to work out. Gotta luv it.
