Guest Anonymous Posted July 21, 2002 Share Posted July 21, 2002 Got the kit from msa to go onto my 4x4 calipers. Problem is cant keep the things from leaking at the caliper. Tried to use the washers available, even some copper ones, nothing. Still leaks. What Ive been trying to do is use the other supplied lines (the ones that say earl's) and find a 90 degree elbow to go in-between. The thing is i cant seem to find any with two male ends and with the appropriate flange to seat with the line, and the caliper insert! Any help will be greatly appreciated. thanks, franklin Quote Link to comment Share on other sites More sharing options...
Guest scca Posted July 21, 2002 Share Posted July 21, 2002 its a regular metric line that goes in the caliper i have custom lines that replace them $60 pr Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 22, 2002 Share Posted July 22, 2002 Ive got 2 sets from MSA and i doubt that i will pay for any more lines. Ive got the one with two female ends, and i have the one with the ring at the end of the line that has the screw that goes through it, with washers and into the caliper. The latter keeps leaking so im not going to use them. I just need to find a 90 degree elbow that has two male ends, and the correct flange to seat with the female end of the line (says Earl's on it) and the caliper insert.. Got any of those for sale?? thanks, franklin Quote Link to comment Share on other sites More sharing options...
QWKDTSN Posted July 23, 2002 Share Posted July 23, 2002 Go to Summit Racing and browse through their fittings. I can guarantee you'll find the right thing. I'd point the way but I don't know if one end of the 90 degree fitting needs to be AN or not. If you know what kind of thread goes into the caliper, you should be able to find one. Should cost three or four bucks. I have a store nearby that's an Earl's distributor so I buy all my fittings locally. Quote Link to comment Share on other sites More sharing options...
