Clarke 180EN Welder For Sale
figured this would be the best place to put this. I purchased a Clarke 180EN Mig welder about 3 months ago. Its never been ran and doesnt even have the plug yet I never bought it and havent had the money to run wiring for 230 volts. I ran into some issues with money after swapping jobs and I need some cash. It has the option to hookup gas and comes with the regulator. It still has the factory warranty. Ill even throw in the auto darkening mask I paid $50 bucks for. Total price s/h and helmet included $415 bucks Here are some specs
here is a pic off ebay. same exact style of welder http://i18.ebayimg.com/02/i/03/53/88/8e_1_b.JPG
NEW Clarke® 180EN 220 Volt 180 Amp (No Gas or Gas) Mig Welder
NEW Clarke® WE6540 Regulator for Argon or Argon/CO2 gas
High Quality for years of dependable service.
Solid state electronic heat control with large PC board for better wire speed control.
Weld steel, aluminum, stainless, copper and cast, requires correct wire and gas.
Operates from standard 220 VAC.
Automatic thermal safety switch prevents overload.
Mig gun with full On / Off safety control.
Mig Gun is non-live with built in gas shut off.
Fan Cooled.
Complete with mig gun, ground lead, gas hose, starter spool of flux core wire.
Requires WE6540 regulator for gas use, Included in this package.
Uses 2 lb. - 4" and 11 lb. - 8" spools - carbon steel, copper, stainless and nickel.
Uses 2 lb. - 4" and 11 lb. - 8" spools - flux core 71TGS.
Uses 1 lb. - 4" and 5 lb. - 8" spools - aluminum .030 5356.
Simple to operate and portable.
Weight: 64 lbs
Max Amps: 180
Min Amps: 30
Heat Settings: Six
Max Open-Circuit Voltage: 30
Variable wire feed control 0 - 700 IPM
On / Off switch
+ / - Polarity control.
Fan Cooled
Thermal Safety Switch
Wire sizes: .023 - .035
Circuit Breaker Req: 25 amps
Input voltage: 220 VAC
Phase: Single
Duty Cycle: 20% at 100% output
Max Metal Thickness: 1/4"
Clarke Factory Warranty: 10/2 - Year Limited Welder Warranty
