solid motor mounts
Guest 400 ci 280z
Guest 400 ci 280z
will using solid motor mounts with a hi-powered engine mess the frame up after i put in new frame rails and everything? i dont want to twist a brand new frame and the car.
The forces due to engine torque are the same. What is different is the amount of vibration (and the resulting forces) applied to the chassis AND the internal engine parts. Not usually a static strength problem, but often a fatigue concern. And every race car I ever worked on with solid mounts shook the hardware loose from one end to the other on a regular basis. Just something to watch out for.
