Guest samstrat Posted July 8, 2007 Share Posted July 8, 2007 I have a '76, but am running a holley 4-bbl, an MSD 6al and an MSD Blaster SS coil and stock distributor. The car is used 100% for autocross/strip and has no lights, nothing. Does the MSD setup take the place of the transistor ignition unit? I am assuming that since the earlier carbed Zs did not have the TIU, and mine is now basically the same as that, that I don't need the TIU any more. Am I correct? thanks Quote Link to comment Share on other sites More sharing options...
speeder Posted July 13, 2007 Share Posted July 13, 2007 You can eliminate the stock 280Z spark box by connecting the distributor's pickup coil (red and green wires) to the MSD's VR input ( purple and green wires, respectively). If you are currently using the MSD's white wire to trigger then the MSD is being fed from the stock "TIU". Quote Link to comment Share on other sites More sharing options...
Guest samstrat Posted July 13, 2007 Share Posted July 13, 2007 thanks, i'll give it a try this weekend. Quote Link to comment Share on other sites More sharing options...
