zmaster Posted July 10, 2007 Share Posted July 10, 2007 on my 1975 280z where is the location of the fuel pump relay, I have lookied in my haynes repair book too many times, and I still can't locate the relay. Can someone help me out? Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted July 10, 2007 Administrators Share Posted July 10, 2007 Under the dash, drivers side, you’ll find either one long relay or two next to each other. Look for something shiny aluminum in color. This will be the EFI relay/s. They are usually two separate relays or in one longer housing, (either way, there are two identical big square connectors for this EFI Relay). I'm sure someone here has a picture of one, if not I can post one tomorrow. Also, the AFM has a switch in it that when air flows through it, say at idle, the fuel pump will operate. Also, when the key is turned to the start position, the fuel pump is supposed to operate. Hope that helps, Paul Quote Link to comment Share on other sites More sharing options...
