4x4 toyota caliper Q?
Guest Pegasus76
Guest Pegasus76
I am thinking about getting the 4x4 calipers from the Toyota...Is it true you can just bolt right on? and space your rotor and everything would be perfect? What else would I need?
Pretty straight forward, the only things i ran into were my 83' turbo rims were rubbing on a hump on the caliper. I was very hesitant at first to shave the hump down, but i got it ground down and fortunately i didnt hit anything.
franklin
I have the stock 240Z calipers on my track/street 240Z, and THEY work great.
Otaku, what will you be using this car for, and how much hp will you be making?
The answers to these questions will determine what, if ANYthing, you need to modify from
stock. Fact is, the Toyo brake calipers have ~4% greater piston area than stock. This means
more front bias, which means you'd theoretically increase your stopping distance (stock setup
is already appropriately overbiased to the fronts). Unless you're making a TON more hp than
stock AND are doing roadrace track work, the stock setup with good pads/shoes and fresh
fluid (trackworthy on both counts if that's what you'll be doing) will suffice.
