v8dats Posted July 16, 2007 Share Posted July 16, 2007 surfing the corvette forum for a friend and ran across this add. thought it would be a killer engine for a z! http://forums.corvetteforum.com/showthread.php?t=1755006 i copied this from the add: It is my original LS1 motor for my 00 coupe, 72k on the bottom, 30k on the h/c, all quality/proven parts used on upgrades. No oil pan or front or rear covers. I have a valley cover for it, but no seal or bolts at this time. Valve covers included. Description: LS1 stock bottom end (72k miles) LS6 heads, comp cam: cam, rockers, comp 921 springs, comp lifters. Center bolt valve covers included, modified to fit the rockers. Cometic head gasket and ARP head bolts. See sig and web page for setup h/c done 30k ago No oil pan or engine covers or knock sensors, the usual. Ported oil pump, double roller timing set, valve covers included. 400 rwhp and rwtq was through 3.42s. Have several dyno sheets. Engine burns no oil, change every 3500 or so, never have to add. Compression and leak-down test done, all good. Quote Link to comment Share on other sites More sharing options...
