L-series AC compressor interchange
Flexicoker
I've got a somewhat functioning dealer add-on AC compressor in my '73, it makes grinding noises and weighs about 40 metric ass tons. Will the later compressors fit my L24 if I have the bracket they mount with? ie. does my block have the threaded holes that the later bracket requires? Where do they mount? My current one mounts above the alternator.
Thanks,
Eric
I switched to a ZX compressor and mounting bracket a few years ago on my 73 and it has been great. As other said, it mounts to the block with 4 bolts on the driver side down low. The mount is aluminum and weighs much less than the original Rube Goldberg contraption. I think I picked mine up at a local JY for about $25. The compressor mounts solid with no mechanism to adjust the belt tension, so make sure you get the idler pulley as well - that's how you adjust the belt.
