gretchen/jason Posted July 28, 2007 Share Posted July 28, 2007 So i got a new cam and lifters for a good deal crane cam grind number 113802 for 100$ never used still in the box . the specs are as follows 109 int lobe center and 119 on the exh 222 int dur at .050 and 234 on the exh with a .467 int lift and .494 exh lift . Is this ok for a supercharged 383 8 lbs of boost cast iron heads 3,000 rpm stall converter may use 3.54 gears not sure but like my 4.11 gears . 1.5 ratio roller rockers full roller . Heads have ben majorly ported to flow the best they can . To the folks reading this what cam do ya use on youre z if its supercharged ? Thanks Jason Quote Link to comment Share on other sites More sharing options...
