Can you ID this turbo???
trwebb26
I want to hop on the bandwagon and get an HY35W Holset turbo for my Z. I've been diligently looking on diesel truck forums and ebay for about a month trying to find the perfect one. I think I may have found it:
http://cgi.ebay.com/ebaymotors/Dodge-2500-Cummins-5-9L-Holset-Turbo-Nice-Condition_W0QQcmdZViewItemQQcategoryZ33742QQihZ004QQitemZ140147660965QQrdZ1QQsspagenameZWDVW
Can anyone confirm that this is in-fact an HY35W?
When I asked the seller - this is the response I got:
Dear trwebb26,s.gifs.gifThe only numbers I see on the turbo are...
4035996...casted into the rusty part right behind the turbo &
12410...witch is stamped with ink on the turbo
And on the front of the turbo it says Holset 3
s.gifs.gifs.gif- 396chevelle67
DIBS IF THIS IS AN HY35W - I'll be bidding this one til the end! :o
Yep that's the same Turbo just called an HE351CW, identical to the HY35 apart from some very minor changes. The black valve on the side can be left in place but disconnected or you can run a PWM signal to it to control the wastegate (boost level). You will need to change the Wastegate actuator though as they dont start to open until 20psi or so.
