gretchen/jason Posted August 18, 2007 Share Posted August 18, 2007 Can one use MSA,s motor mounts and JTRs trans mount at the same time . I like MSA,s motor mounts no welding no fuss just bolts rite in , in just a few minutes . But i hated MSA,s tranny mount it sucked . Jason Quote Link to comment Share on other sites More sharing options...
wheelman Posted August 18, 2007 Share Posted August 18, 2007 Shouldn't be any reason you couldn't use JTR's tranny mount with the MSA motor mounts. BTW: JTR motor mounts don't require any welding either. Wheelman Quote Link to comment Share on other sites More sharing options...
gretchen/jason Posted August 19, 2007 Author Share Posted August 19, 2007 Oh the Jtr mounts dont huh . Go figure some guy down the streeet with a V8 z says he has the Jtr mounts and he had to weld them in oh well so it is . Do they mount in the same place or should i ask does the engine sit any farther back with the Jtr mounts . The msa mounts put my engine back far enough that my large style HEI distrubitor with the coil mounted on the distrubitor has just under 1/4 inch of clearance between it and the firewall . If they mount in the same place and i wouldnt have to get another driveshaft i may just get the entire JTR set up . Jason Quote Link to comment Share on other sites More sharing options...
strotter Posted August 19, 2007 Share Posted August 19, 2007 Perhaps he make them himself - the plans are in the book. The distributor is in about the same position as you describe with the JTR mounts - there's some wiggle room, as people generally slot the mounting holes in the Z flanges. Quote Link to comment Share on other sites More sharing options...
gretchen/jason Posted August 26, 2007 Author Share Posted August 26, 2007 So i did go ahead and order mounts from JTR what a horiable experience . They were rude and kept trying to sell me stuff i didnt want . I said to them i needed engine and trans mounts only nothing else . Well he started shoving the V8 conversion manual down my throat , i said this is my 3rd V8 swap he said well this will help ya get it rite !!!!! Then he tried selling me the speedo cable adapter i said no i have a electronic speedo but he kept trying anyway and then kept trying to sell me other stuff no matter how many times i said no ive got it covered . I dealt with JTR once before about the radiator i bought from them not keeping my V8 cool and they said it was my engine not the radiator so i then bought a 2 row rad problem solved but that is another story . I now only hope they come with instructions on which mount goes where but i will say the price was good 140$ compared to msa 230$ something . Because when i ordered the radiator mount i had to figure it out my self not a big deal but still its the point . Jason Quote Link to comment Share on other sites More sharing options...
getZ Posted August 26, 2007 Share Posted August 26, 2007 I would check the driveline angle if you are going to mix and match parts of different manufacturers. When I went to order mines, they were out of stock, so I made my own with rectangle stock and 5/8 flat stock. I like mines better anyway. It has notches for exhaust clearance, plus it gave me another couple inches of ground clearance. This isn't a great pic, but you can get the idea. BTW the exhaust was not tightened down at the time so it's slightly rotated and lowered. I forgot to mention there is a driveshaft hoop there in the picture between the exhaust that is not part of the crossmember. Quote Link to comment Share on other sites More sharing options...
