ktm Posted August 27, 2007 Share Posted August 27, 2007 I am using the Wolf V500 EMS in my build. The Wolf system requires injector pulse width as an input versus load (as measured by MAP or TPS). I've developed a spreadsheet to calculate my injector pulses based on an AFR map for MAP load cycles and RPM. The spreadsheet also calculates duty cycle per RPM and load. I need someone to do a quick check on my injector pulse width calculations if possible. I know that this is for the MS system, but the Other EMS forum is a little dead and I figured that the folks here may have a clue as to these calculations. The RPM intervals and Load % in my spreadsheet are the Wolf standard intervals. I calculated the pulse widths for maximum boost first, and then reduced the pulse width based on the density ratio for different load cycles. Thanks. Injector Pulse Width.zipFetching info... Quote Link to comment Share on other sites More sharing options...
