fuel only code
280tyler
You can use MSnS-E for fuel only useage too. But if you want to make a lot of the extra tuning options disappear and go to 8x8 tables, you can reload it with standard MS-I firmware.
Here's the code file:
http://www.bgsoflex.com/v2.98/megasquirt.s19
It's easiest to load with the MS-II downloader program, which works for MS-I too:
http://www.not2fast.com/megasquirt/ms2dl/ms2dl104_setup.exe
  280tyler said:
where do i get the fuel only code and how do i download it to my ms?
i have a ms1 v3 it has the msns-e code on it right now but i want to go with fuel only i've been having a hard time finding how to update my code
thanks
You can also run extra code in a fuel only mode. Keep the stock ignition, and trigger the MS off the negative coil terminal. Just leave the ignition output unconnected.
