Guest BillV Posted October 5, 2002 Share Posted October 5, 2002 Does anyone know the formula for finding wheel diameter from the tire size? I used to know it, but forgot. Quote Link to comment Share on other sites More sharing options...
Guest Thurem Posted October 5, 2002 Share Posted October 5, 2002 First you wanna find the diameter of the tire. The side wall height is the width (first number)multiplied by the aspect ratio (second number), then you wanna add the size of the rim. For example: 245/45-16 The side wall height would be 245 mm (millimeters) times .45 (aspectratio is 45% of the width) equals 110.25 mm. The diameter of the rim is 16" times 25.4mm/" equals 406.4 mm. Hence the diameter of the wheel is 110.25mm + 110.25mm + 406.4mm = 626.9mm (note you have two sidewalls, top and bottom, in the diameter). If you want it back in inches, you go like this: 626.9mm divided by 25.4mm/" =24.68" Piece of cake really... Thure Quote Link to comment Share on other sites More sharing options...
