Bics280z Posted September 14, 2007 Share Posted September 14, 2007 I wanted to know how hard it was to change valve seals, because my car is leaking oil from the valves pretty bad, it gets oil on the car when driving + i think valve cover gasket leaks. Lightly smokes. Also is it possible to do without removing the head, I know you should be able to compress the cylinder then remove the springs and do it that way by using a compressor and spark plug hole adapter, is that true? thanks Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted September 14, 2007 Administrators Share Posted September 14, 2007 Do you own a shop manual for your car? All of your posts thus far have been maintenance related and come across as if you don’t own a manual for your car. Oil on the car has nothing to do with valve stem seals. Worn tired valve stem seals cause the engine burn oil, i.e. smoke. Typical for these cars with their age to have hard valve stem seals, and yes, they can be changed without removing the head. Valve cover gasket leaking is a common cause for a messy oily engine. Quote Link to comment Share on other sites More sharing options...
Bics280z Posted September 16, 2007 Author Share Posted September 16, 2007 so how do i change them? Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted September 16, 2007 Administrators Share Posted September 16, 2007 http://www.Zcar.com If you don’t like those guys, then try; http://www.classiczcars.com Good luck, Paul Quote Link to comment Share on other sites More sharing options...
Bics280z Posted September 17, 2007 Author Share Posted September 17, 2007 that didnt help at all Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted September 17, 2007 Administrators Share Posted September 17, 2007 Which Nissan V-6 do you have in your ’78 280Z? Quote Link to comment Share on other sites More sharing options...
