Chevy V-8 cooling
Guest wwwynn
Guest wwwynn
I built a PAW "blower motor" kit in 1989. Low compression chevy 350, B&M 144 cu in blower, B&M superjection throttle body fuel injection. Chevy 350 auto trans. I installed it in my 1971 Datsun 240-Z. Initially there were cooling problems eventually solved with a 3 core cross flow radiator, a add on trans cooler, a add on oil cooler. It has run well since, until the last several months when it gains heat at highway speeds. I suspect I need a cooling system update after nearly 20 years.
Question: What to do.
A Howe or Ron Davis Al. radiator or some other?
An electric puller fan? which one?
Use a shroud and stock fan?
I would really like to do this once and do it right.
help, bill wynn
http://www.google.com/custom?client=pub-3543793485173468&forid=1&ie=ISO-8859-1&oe=ISO-8859-1&cof=GALT%3A%23008000%3BGL%3A1%3BDIV%3A%23336699%3BVLC%3A663399%3BAH%3Acenter%3BBGC%3AFFFFFF%3BLBGC%3A336699%3BALC%3A0000FF%3BLC%3A0000FF%3BT%3A000000%3BGFNT%3A0000FF%3BGIMP%3A0000FF%3BLH%3A50%3BLW%3A126%3BL%3Ahttp%3A%2F%2Fforums.hybridz.org%2Fimages%2Fmisc%2Fvbulletin3_logo_white.gif%3BS%3Ahttp%3A%2F%2F%3BFORID%3A1&domains=forums.hybridz.org%3Bclassifieds.hybridz.org%3Balbum.hybridz.org&hl=en&q=cooling&sitesearch=forums.hybridz.org
I searched using the search function just under "cooling" and received about 10 or so threads covering the issue. I'm sure that "fan," "Ron Davis," "Griffin," "radiator," and a number of other possibilities would yield even more results.
What cooling come down to is airflow. If you read within the forums and use the search function, you'll uncover a lot of info about the Z car's design and how to maximize the airflow through the radiator. Good luck with finding a solution!
BY the way, is your V8 swap set up JTR or Scarab?
Davy
