How far off????
I have done many mods to my Z car and it has just hit me that my speedo has to be way off. I originally had 195/70/15 wheels and a 3.54 diff. The new set-up consists of 225/50/15 tires and a 3.7 diff. How far off is my speedo now? When I upgrade to 17" rims what size tires do I need in order to correct my speedo reading? Thanks
web page you may need the white 19 tooth speedometer cog for the 3.90 diff.Check the above webpage out, then figure out the diameter of your new tires to add in on which of the 5 cogs you need from Nissan
Here's the formula I used to figure out which speedo gears I needed to recalibrate my speedo after changing rear end gears and tire sizes...
Note: Drive gear refers to the gear that is on the transmission output shaft.
The driven gear is located in a removable housing usually in the tailhousing
of the transmission.
# Drive Teeth X Axle Ratio X Tire Rev. per Mile
---------------------------------- = # Driven Teeth
1024
Use the following formula to calculate the Tire Rev. per Mile for the above formula.
20168
---------------- = Tire Rev. per Mile
Tire Diameter (inches)
Don
