Stock Knock Sensor Output Voltage....1 volt???
ktm
My EMS has the ability to log and output on quite a few channels. Currently, I have hooked up the stock knock sensor (L28ET) to the EMS. Upon receiving a signal, it pulls to ground and an LED lights up. The light works as intended when I put the threshold value to 0 volts.
In order for this to work correctly, though, I need the correct knock sensor peak output voltage. Does anyone have any idea? A search on the 'net indicated that some sensors output around 1 volt. What about our knock sensor?
Cheers,
Bo
