There's no wastegate?!!!
yenghua
if it truly has no wastegate that it is not a stock Z unit.
are you sure that the vac pod to open and shut the wastegate is just missing. if so that you can get 1 from flea bay or maybe someone here has 1. I might have another.
If you need an external wg than TIAL is the best imo and probably most others.
That is the wastegate actuator, it opens a flap inside the turbine housing which is referred to a a wastegate.
Pick one up off ebay and youll be good to go. Fitting a external gate is a bit of work and is really only nessecary if you change turbos and need the extra flow.
