Fuel vaporisation precautions
2savage
Setup is triple 45 DCOE's to a cannon intake and Stahl headers. Head is worked with big valves, flowed and high compression.
So, I here's the plan....
1) wrap the headers
2) install metal heat shields under each carb http://www.pegasusautoracing.com/bigpicture.asp?RecId=5379
3) put heat sheild tubing over the fuel line feed
4) use two fuel pumps, one near the tank and a second under the hood
Is there anything else I can do? How about those plastic spacers that fit between the carb and the header?
