philfree Posted November 28, 2007 Share Posted November 28, 2007 Hi I only just brought my s130 last week. Which is a 1979 na 280zx 2+2 auto i have come across a 2.4e 5 speed manual skyline which i think is 1985 (will be checking in the next few days) my question is how much work is it to fit the gearbox into my 280zx. That is all the information i have on the skyline please let me know if you need more information. Thanks Any help much appreciated Quote Link to comment Share on other sites More sharing options...
roninjiro Posted November 30, 2007 Share Posted November 30, 2007 i've done a auto-manual swap before, but i used an L-series gearbox from a 240z, but... you wanna use the skyline manual and that i'm sure will not just bolt up to the L-series engine you have without an adapter i would imagine. but if it does work you will need these: -custom driveshaft -custom gearbox mount -manual brake pedal assembly -flywheel, clutch, pressure plate (assuming you can use a stock 280zx flywheel) -clutch master, and slave cylinder, with lines -etc... Quote Link to comment Share on other sites More sharing options...
philfree Posted November 30, 2007 Author Share Posted November 30, 2007 Hi Thank you for your help I don't know how many skylines came out with the l24 but this skyline did i double checked the year and it's a 1982 with l24e motor i already have the alternator off of this car to replace the one on my 280zx. having said that would i still need a custom drive shaft and custom mounts? Sorry i didn't mention/ make it clearer in the first post Thanks any help appreciated Quote Link to comment Share on other sites More sharing options...
roninjiro Posted December 1, 2007 Share Posted December 1, 2007 since the engine is an l24, now for this last question, are the input flanges on your differential and the skylines the same? (or are the differentials the same?) Quote Link to comment Share on other sites More sharing options...
philfree Posted December 8, 2007 Author Share Posted December 8, 2007 Hi sorry for the late reply i was away for a few days. I don't know about the input flanges. But i have been down and seen the guy (it's at the local wrecker) and he will sell me the whole car minus alternator, front wheels, and front bumper for $200AUD so ill more or less have the whole car. So now i can get the whole car what i would like to know do i need anything else will all the parts form this car be enough to convert my 280zx to manual? Thanks for the help Much appreciated Quote Link to comment Share on other sites More sharing options...
roninjiro Posted December 9, 2007 Share Posted December 9, 2007 you should have about everything you need if you get the whole car. just see if the driveshaft is a direct fit, if not take the two driveshafts to a machinist to modify the two to work for your car. other than that i dont see any other problems. Quote Link to comment Share on other sites More sharing options...
philfree Posted December 9, 2007 Author Share Posted December 9, 2007 Hi Thanks for the help. I may post my results depending on weather someone wants the information or not. So please post or pm if you want to know the results Thanks much appreciated Quote Link to comment Share on other sites More sharing options...
