Guest Anonymous Posted January 17, 2003 Share Posted January 17, 2003 I thought i read somwhere that with regular springs (ie. not coilovers ) 17's where a difficult fit ? also has anyone used the honda wheel adapters ? Quote Link to comment Share on other sites More sharing options...
Guest greimann Posted January 17, 2003 Share Posted January 17, 2003 17x7 or 17x7.5 wheels will fit very nicely on a stock suspension. Lots of discussion in a few recent threads in this forum. Here is one example of a Honda adapter installation. http://home.earthlink.net/~dvgreimann/wheels.html Quote Link to comment Share on other sites More sharing options...
Guest gerryG Posted January 18, 2003 Share Posted January 18, 2003 here is another http://zdriver.com/rides/detailride.php?cat=2&relIdx=16&vehId=109 17X7 with Honda spacers Work Fine Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 22, 2003 Share Posted January 22, 2003 How are those holding up to like 400+hp ? think that is a wise idea ? Quote Link to comment Share on other sites More sharing options...
Modern Motorsports Ltd Posted January 22, 2003 Share Posted January 22, 2003 Originally posted by LT_ZT:How are those holding up to like 400+hp ? think that is a wise idea ? Here's some prior threads, lots more thru the search function....been used on 400hp and above for years now when done correctly. http://www.hybridz.org/ubb/ultimatebb.php?ubb=get_topic;f=6;t=001732#000012 http://www.hybridz.org/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=6;t=001590 http://www.hybridz.org/ubb/ultimatebb.php?ubb=get_topic;f=10;t=001085#000000 http://www.hybridz.org/ubb/ultimatebb.php?ubb=get_topic;f=10;t=001363#000000 One of the above posts is by a big block hybridZ owner running 'em. Many members have weighed in on the above noted threads already. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 22, 2003 Share Posted January 22, 2003 hey Ross what do you mean done correctly ? i want to get some 17's and use your adapters on my 72 240. What kind of offset do i need to look for ? or is there just a specific Civic year or something ? thanx Quote Link to comment Share on other sites More sharing options...
Modern Motorsports Ltd Posted January 22, 2003 Share Posted January 22, 2003 Originally posted by LT_ZT:hey Ross what do you mean done correctly ? i want to get some 17's and use your adapters on my 72 240. Done correctly summarized as in your wheel studs have a known history (ie. never overtorqued), your chosen adaptors are made to fit your hubs and studs properly, all resultant fasteners are proper spec/quality and properly torqued and checked with reasonably frequency (same as running ordinary wheels without spacers). For proper thickness, if you want to go wider than 7" width or move away from the OEM wheel centreline, then you'll want to measure up your ride and then pick a likely new rim candidate to compare specs/expected clearances to arrive at a thickness. If you want typical 7" width at OEM centreline then my stocking units are fine. Custom units are only a couple weeks time till they ship typically if you want a specific non-typical wheel or location. My website has a useful link under the product description for checking clearances as well. Quote Link to comment Share on other sites More sharing options...
