aarang Posted December 29, 2007 Share Posted December 29, 2007 I was pulling my car out of the garage over Christmas for a spin around the block. About a minute after it was running I heard a squealing noise from the front of the engine. I pinpointed the noise to be coming from the distibutor. I pulled the distributor out and it seems that the top bearing/bushing is either worn or just really dry. There is really no slop in the shaft so I'm hoping to just clean and lube it. My question is, has anyone completely disassembled a 82/83 turbo Dizzy? I removed the rotor post,chopper wheel and the small plate below the chopper wheel that has the tension spring under it, and the tension spring. I also removed the collar on the bottom drive side as well. The shaft will not come out like the N/A dist. I really don't feel like damaging this thing as the car runs good with this dizzy. Any help or insight is appreciated! Thanks Aaron Quote Link to comment Share on other sites More sharing options...
