is there a good diagram for no relay board install
driftz240
Mobys writeup is correct for ms1 with hei module. If you have the wiring diagram that came with your m.s unit, use that diagram and make your own relay setup. Cygnus has pics of his relay setup on here. I think the post is Wiring up megasquirt. Hope that helps.
If you bought the wiring harness with your megasquirt the wires are labeled, use the exact same wires the diagram shows like you have a relay box in the car. If that makes sense. Run the ignition wire and Fidle wire like the diagram shows for 2.2 board. Check out msefi.com for wiring up a 2.2 board. I have ms2 with a v3.0. Are you using one hei module or two?.
