73G-nose Posted January 13, 2008 Share Posted January 13, 2008 This transmission came as a spare with a race car I've since parted with, and I've hung onto it as I was told it was an actual Datsun close ratio comp box. Before I decide what it's fate will be, I wanted to verify if it is something beyond the garden variety 5 speed. As you can see from the pics it's in need of an overhaul, or perhaps destined only as a spare parts donor. I don't think it's a "dog leg" style, as it seems to be a conventional 5 speed shift pattern. The tooth counts in black are for this trans...the yellow counts are what I could find listed for a standard 5 speed (page 146 of the "how to modify datsun engine and chassis manual). Assuming I counted correctly (three times) it does appear to be different than the standard ratio. I couldn't find any ID numbers on the case that may have helped solve the mystery. –Thanks for your help Quote Link to comment Share on other sites More sharing options...
ezzzzzzz Posted January 14, 2008 Share Posted January 14, 2008 It appears to be a standard 5 speed. There's no cast ear off the passenger side just ahead of the outout. I'm assuming there is one on the drivers side that we can't see. That would indicate it is a late 70's or early 80's box. Brass syncros would not be found in a comp box to my understanding. My early roadster 5 speed does have the split steel syncros. What it came out of is uncertain. That might explain the gearing differences. Quote Link to comment Share on other sites More sharing options...
73G-nose Posted January 14, 2008 Author Share Posted January 14, 2008 Mark, Yes, you're correct. I've since verified it as nothing more than a worn out old standard 5 speed. So much for the previous owners integrity. I never was very informed on the many old Datsun transmission variants, as you can tell. I upgraded to a g-force T5 in my car, and have no plans of reverting back. Thanks for the help... Quote Link to comment Share on other sites More sharing options...
HowlerMonkey Posted January 21, 2008 Share Posted January 21, 2008 Weren't the 5 speeds offered in the 280z closer ratio than the ones offered in the 280zx? Maybe that's what the previous owner was thinking. Quote Link to comment Share on other sites More sharing options...
