Blown77Z Posted January 23, 2008 Share Posted January 23, 2008 I've narrowed down the Centerforce DF clutch as my clutch of choice for the 02 LS1/T56, http://store.summitracing.com/partdetail.asp?autofilter=1&part=CTF%2DDF017010&N=700+115&autoview=sku Summit's site states: "This clutch assembly requires the replacement of the hydraulic cylinder with GM part number 12565145. The GM part includes the cylinder and release bearing." NOTE, this part number has been changed by GM to: 15046288 GM Part, which is $132 dollars and is NON-RETURNABLE: http://www.gmpartsdirect.com/results.cfm and type in 15046288 (won't keep search result active with link) Has anyone replaced their stock units with the above parts? I'm wondering if they changed any dimension of the fittings with the new part and if the mcleod quick connect line and fittings with work with it (that I have already).... Would like this swap to go as easy as possible without long delays Sorry for the rambling on, trying to clarify so many different parts and their compatibility is kind of frustraiting. Quote Link to comment Share on other sites More sharing options...
