Guest datoracer Posted February 1, 2008 Share Posted February 1, 2008 Hi all, this is my first post to this site, and I need some of your expert help in trying to Identify what this piston may be out of. This piston is out of a L28 block running standard L28 crank and rods with a 22mm pin. The pin or Compression Height is 39mm, The crown height is 7mm's. On the inside of the Piston it has what looks like a nissan symbol with SO100 below this. If anybody has any ideas as to what this piston may be out of it would be much apreciated or have any surgestions what i could use for a 89mm bore with the 39mm compression height as a replacement it would be much apreciated. Cheers Quote Link to comment Share on other sites More sharing options...
