Guest John Adkins Posted April 10, 2000 Share Posted April 10, 2000 Does anyone have a Z with an automatic transmission with a manual valve body? I was just wondering if this might be an option, since I would like to do my v8 swap as economically as possible, which for me means using an automatic, but I like manual shifting. Any thoughts? Thanks, John Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 11, 2000 Share Posted April 11, 2000 quote: Originally posted by John Adkins: Does anyone have a Z with an automatic transmission with a manual valve body? I was just wondering if this might be an option, since I would like to do my v8 swap as economically as possible, which for me means using an automatic, but I like manual shifting. Any thoughts? Thanks, John John, I have a Turbo 350 in my car with a shift kit. I shift the car manually and it works well. It will spin the tires a car length on the 1 2 shift. This trans has the ability to adjust **** firmness with the adjustable modulator valve and it is fairly easy to adjust from under the car. I would omit the manual valve body option. You can always add it later and can install it without removing the trans. Hope this helps Bubba Fett Quote Link to comment Share on other sites More sharing options...
