Electric vacuum pump
510six
http://www.turbobuick.com/forums/general-turbo-buick-tech/234420-crankcase-evacuation-lt1-smog-pump-how.html
I am going to use an LT1 smog pump in conjunction with an aircraft style air/oil seperator to control crankcase pressure under boost and run the pump for 10 or so seconds after boost using an output from the AEM EMS to turn the pump on and a time delay relay to keep it running. I will let you know what the results are in the next couple of weeks.
