Turn Signal Problems
Guest Jconnellr
Guest Jconnellr
Hey guys my turn signals will not work. Then one day out of the blue after sitting for a week or so they worked but there was a loud clicking noise coming from the engine compartment near the coil. Then the next day they didnt work again and havent since. Also when i turn my hazards on only the front right and rear right lights work. And Suggestions? Its a 1974 260z
_James_
I've had that happen. My heater core went south and leaked its juices all over the wiring near the turn signal switches. Turned on the turn signals, which shorted out the wiring. Replaced the wiring and had to replace the heater core and turn signal switch as well as well. A royal PITA. At best, a little wirework and it's all good. At worst you'll replace wiring and the turn signal switch ($200 for the switch assembly)
--rat
