Guest Fast Frog Posted December 2, 2000 Share Posted December 2, 2000 Question for those of you who have had experience with T-5s and 700R4 trannys in your ZV8 in the JTR setback position. Are the driveshafts the same length for both trannys-all else being equal? Quote Link to comment Share on other sites More sharing options...
Modern Motorsports Ltd Posted December 3, 2000 Share Posted December 3, 2000 beware for comparisons that you can swap shorter tailhousings on a 700R4 trans from TH350's etc(like I did as shop didn't have a speedo combo close to what I needed in the OE 700R4 tail, 350 tail supports more speedo gear combo's) so not sure if that could make it same (adds a possibility anyhow) Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 3, 2000 Share Posted December 3, 2000 According to JTR they're the same at 20.5 inches yoke centerline to yoke centerline, with they're mounts. (They do caution to measure it in the car with the engine and trans mounted as your distance may vary a bit...) Lone Quote Link to comment Share on other sites More sharing options...
